Alloys
I would get the guy to read the PCD off the back of the alloys. Should be on one of the spokes.
Your PCD is 100 - they wont fit if they are 110!
Says his vectra is 110 and it'll fit a SMALLER pcd :thumbup:
So they are 17s on 40 tyres will they affect my speedo?
Depends what your car was designed for.
What are the standard tyres on a 1.4 MPi Fabia?
Edited by andy2407
Smaller than 110 can be 108, 106, 100! Bit of a gamble!
My bad! ;)
Mine are 14 and 60.
Mine are 14 and 60.
And what width?
Looks like the ones he's selling are 205/40/17
205/40 17 is fine for a Fabia.
And what width?
Mine are 185/60/14
Why does the width affect anything?
They finished at about £79 but I was at work :(
OK - probably not relevant if you didn't win, but for future reference anyway......
I asked the width because the figures you gave (60 for your current tyres and 40 for the new ones) are the aspect ratio (ie the ratio of the height of the tyre sidewall expressed as a percentage of the width) and thus meaningless on their own
If you got to Car Bibles : The Wheel and Tyre Bible Page 2 of 2 there is a little calculator that helps you compare different tyre sizes.
As well as knowing the tyres will fit (as confirmed by Lummox) you also wanted to know the effect on your speedo.
For your example, the results from the Car Bibles site are: -
You are just outside the 3% rule of thumb, but should be OK as long as you are aware of this.
I reckon 3% is a little too small a "gap" to keep within. I reckon you can go to at least 5% fairly safely. My car came with the same steels as above, and now runs 215/40 R17 which is pushing that %% a bit more still.
The mongrel was made to push %%'s :thumbup:
Cool that website is pretty useful.
He's just said they are 195/40/17 and 5x100.
Looks like i'm in.
I've got a pretty good chance seen as he hasn't mentioned any of this in his description.:thumbup:
