Felicia door lock
I have a Felicia 1.3, 2000 model. The driver door lock barrel just spins. Having investigated, I have found that at the back of the barrel there is a die-cast component with cams to operate the lock. The cams move a lever which pushes the internal lock post up or down.
This die-cast item has split in two, and I found the pieces in the bottom of the door. Does anyone know where I can get a replacement for this part? I am trying to avoid replacing the lock completely as this would mean a new key which would not match the ignition.
Thanks.
You wont get a replacement for this part and will have to get a complete lock, either new or preferably second hand.
You can then change the end over, that way you can use your original key.
  • 5 years later...
Just had to replace this part on my other Felicia, easy enough to do, the only hard part is getting the white plastic anti-theft shield back in place.
Had the same on mine the bit that's broken is discontinued at skoda as above find a replacement lock or swap the sides over
  • 2 months later...
I'm breaking a Mark2 Felicia if you still need this part....
Had a broken lock a couple of years ago. Whole new lock from the dealer, made to fit my key.......£18
