Airbox question...
Whilst fitting my new panel filter last night I noticed a bit of rubber going over the cold air inlet. I worked out that it was the seal that goes between the pipe and airbox and tried to tease it back but managed to snap it :o In my defence the rubber was all cracked and brittle!
I have now removed it completely, is this going to cause any problems? My thought was a tiny amount of hot air getting in around the pipe but nothing else?
On a side note, after lifting the airbox lid I found quite a sizable insect on top of the filter :eek: Only reason it was still there was its wing was nipped between the rubber seal on the filter and the airbox lid. Would that have caused problems if/when the thing made it into the air intake?
Would have got shredded by the turbo - but probably wouldn't have done your turbo blades any favours!
