temp sensor wiring clip
Which is the best way of releasing the temperature sensor wire clip? I've had a look at the clip, but I would rather ask for advise before I go ahead & break it.Oz.
You mean the actual connector itself?
Hold connector between thumb and forefinger with your thumb on the raised tab. Pull thumb backwards which pulls the tab inside up, push the connector in slightly and withdraw.
