Lit up like a Christmas Tree - dead PAS
So, my dash is beeping, lit up like a christmas tree, PAS dies, tach and temp guage go nuts. I have read every single one of spevie's posts I could find. It seems the poor guy never figured it out? Makes me feel really hopeful....
Car:
2002 Fabia Classic. The super simple model with nothing to write home about. Heated seats, headlamp washers, left hand drive, 90A alternator, ABS.
Here's what I have done:
- soldered sense wire (D+ blue from alternator)
- voltage seems to be at 14.0-14.2v when running (measured with a ScanGuage II, thus read every 2 seconds)
- Bought a new battery 12.5v when off. (62ah to replace the aged 55ah that came with)
- new metal PAS position sensor
- cleaned out as much debris as I could throughout the engine compartment. I live in a forest, so there were lots of maple seed and leaves stuck in various places.
- removed the soaking wet foam from around the PAS pump, hosed with copious amounts of WD40.
Weather/road conditions:
-15 C to +5 C and lots of snow/ice/mud on the extremely rutted country road.
Current issues:
- Airbag light on (wasn't on until Santa came to town)
- Intermittent Christmas effect, usually after a bit of a drive, or just pulling in to a parking spot
Tools I don't have:
- VAG-COM
Part on order:
- voltage regulator
- VAG-COM
Plans for the weekend:
- check all major wiring between alternator and battery.
Out of curiosity, did spevie end up pushing his car off a cliff or did he get it fixed? I now drive with ear plugs since I know nothing is really wrong with the car.
Edited by snp
highlight "intermittent" under 'Current issues:'
Ouch! Sorry I've no answers but I thought that someone should post a reply to make you feel welcome! Pity about Santa "giving" you a an airbag problem - he gave me the later version of VAG-COM or VCDS, maybe he got our addresses mixed up - sorry.
Check for debris in the plenum chamber, if water collects in there it can get into the wiring loom, and cause all sorts of problems.
I have the Scandinavian PDI done to my loom, so about 10 cm of the sheath is gone right above the body member that collects water and debris. The loom is also suspended above it by about 8 cm. In other words, if water gets it, it gets out, too. Regardless, I'll be ridding the car of all the excess debris it has collected over the years.
I'm starting to wonder if there is some other common wear location in the circuit that feeds the PAS pump. My hypothesis is that potentially something is worn/corroded in the signalling portion of the PAS and can potentially be affecting the board inside the pump. My pump just looks corroded right about where all the cables go into it. There was also copious amounts of debris collected there. Does anyone have experience rebuilding one of these? Or pictures of the circuitry/guts?
Another reason why I am suspecting the internal circuitry of the pump is the fact that I hit a ditch about when the PAS stopped behaving like just a PAS sensor failure. The low speed impact was a direct hit on the pump. It makes me wonder if the seals on the pump make have given way a bit to allow water ingress there.
Is this plausible?
A second option (which requires VAG-COM to diagnose) is the ABS module intermittent failure. It also suffers from water ingress and luckily is a known Skoda design flaw. That means I might be able to get some sort of compensation for the fix. I found it in this link:
http://briskoda.net/maintenance-performance/help-dash-lit-up-like-xmas-tree-dodgy-abs-module/86997/
The description of the dash lights is similar, however the speedo and gas guage work fine. It's the tach and the temp guage which fail on mine. My ScanGaugeII still receives the correct information via the OBD port for both tach and temp.
Added note: ABS functions on a road test when in Christmas mode.
Edited by snp
found info on ABS module, road tested ABS in xmas mode
Good times. I got a cheap-o ebay POS for way too much considering it ain't worth a damn. Regardless, here's what I got before and after clearing the codes I could get at:
BEFORE:
VAG-COM Version: Release 409.1-S
Chassis Type: 6Y - Skoda Fabia
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01: Engine
Controller:
Note: Can't Synch Baud Rate
Address 09: Cent. Elect.
Controller: 6Q1 937 049
Component: BORDNETZ-SG. 1S30
Coding: 09522
Shop #: WSC 13765
6 Faults Found:
01321 - Control Module for Airbags (J234)
49-10 - No Communications - Intermittent
01312 - Powertrain Data Bus
37-10 - Faulty - Intermittent
01309 - Power Steering Control Module (J500)
49-00 - No Communications
01314 - Engine Control Module
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
00906 - Horn (H1)
28-10 - Short to B+ - Intermittent
Skipping Address 15-Airbags
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN 1S30
Coding: 00014
Shop #: WSC 13765
4 Faults Found:
Address 46: Central Conv.
Controller: 6Q0 959 433 A
Component: 01 Komfortgerát 0002
Coding: 00019
Shop #: WSC 13765
No fault code found.
End --------------------------------------------------------------------------------------------------
and the...
AFTER:
Address 01: Engine
Controller:
Coding: 09522
Shop #: WSC 13765
2 Faults Found:
Coding: 00014
Shop #: WSC 13765
2 Faults Found:
Coding: 00019
Shop #: WSC 13765
I couldn't get into many of the modules, in particular engine and ABS, so those bits are not interrogated.
So now what? Push it off a cliff? It drives fine, just beeps all the damn time.
So I spent the day cleaning all the crap out of more nooks and crannies. There sure was a lot, but I think I got most of it. BTW, who in their right mind puts a wiring loom through a low point ina location designed to collect water, then puts carpeting around the wiring loom and the computer? And then fasten everything with one-time use plastic screws? Is failure designed in? Ha!
Regardless, got a new code. Fun times, I tell ya.
Address 09: Cent Elect
01312 - Power Train Data Bus
37-10 Faulty
I have a feeling that it has to be some central hub that is all screwed up since I get every error code in the book (like ABS, PAS, etc). They go away and come back intermittently. Anyone know where connections to this thing can be located? Manual and *real* Vagcom are on order.
Edited by snp
I seem to remember having a problem "talking" to the engine controller on my wife's BBY engined Polo 9N with VAG-COM 409.?? - so you might have more success if you alter the baud rate and try again. As for your other problems I've no answers other than I did manage to talk to the ABS system okay using VAG-COM 409.??.
My guess now is that after I hit the ditch (really not hard, but enough to crack plastic), the PAS is having some kind of internal short dropping communications across the board. It's the only consistent fault aside from the Powertrain Data Bus (whatever that is).
Question becomes.... what other PAS pumps can I drop in there? I finally have the real VAG-COM and can do the work myself.
Am I insane, or is this making sense?
Here are some reads after clearing once or twice.
Monday,06,April,2009,19:05:46:46137
VCDS Version: Release 805.3
Data version: 20090213
Chassis Type: 6Y - Skoda Fabia I
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
Address 01: Engine Labels: 036-906-034-APE.lbl
Part No: 036 906 034 BL
Component: MARELLI 4LV 3699
Coding: 00031
Shop #: WSC 13765
TMBJC26Y223288819 SKZ7Z0A0919005
1 Fault Found:
18056 - Powertrain Data Bus: Failure
P1648 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 09: Cent. Elect. Labels: 6Qx-937-049-B.lbl
Part No: 6Q1 937 049
Coding: 09522
Shop #: WSC 13765
3 Faults Found:
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Coding: 00014
Shop #: WSC 13765
3 Faults Found:
Address 25: Immobilizer Labels:
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 A
Coding: 00019
Shop #: WSC 13765
Monday,06,April,2009,19:24:01:46137
Coding: 00031
Shop #: WSC 13765
1 Fault Found:
Readiness: 1010 0001
Coding: 09522
Shop #: WSC 13765
3 Faults Found:
37-00 - Faulty
Address 17: Instruments Labels:
Coding: 00014
Shop #: WSC 13765
3 Faults Found:
37-00 - Faulty
Coding: 00019
Shop #: WSC 13765
Monday,06,April,2009,19:30:14:46137
Coding: 00031
Shop #: WSC 13765
1 Fault Found:
P1648 - 35-00 - -
Readiness: 1110 0101
Address 03: ABS Brakes Labels:
Coding: 09522
Shop #: WSC 13765
1 Fault Found:
Coding: 00014
Shop #: WSC 13765
1 Fault Found:
Coding: 00019
Shop #: WSC 13765
1 Fault Found:
79-00 - Please Check Fault Codes
Update, because I know you are all so interested. You are all sitting at the edge of your seat either grinning that you know the answer or are wondering if I'll ever figure it out. The saga continues...
Without a Haynes or any other manual, I figured out which fuses are to the PAS and yanked them. I won't tell you what they are since nobody in this forum has said what they are. I also won't tell you where they are either. Heck, there could even be more than 4 fuses to the PAS scattered throughout the car and impossible to find without dismantling everything. And then you need vag-com to get the secret code to allow you to remove the fuse.
So, in short, I removed the power lead to the PAS pump and magically EVERY SINGLE ERROR CODE went away. Communications between vag-com and the car became super fast and easy. Wanna see?
BEFORE:
Tuesday,07,April,2009,15:23:14:46137
Coding: 00031
Shop #: WSC 13765
Readiness: 1010 0101
Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS.lbl
Part No: 6Q0 907 379 C
Component: ABS 5.7 FRONT V00
Coding: 00044
Shop #: WSC 13765
1 Fault Found:
Coding: 09522
Shop #: WSC 13765
4 Faults Found:
37-00 - Faulty
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 H
Component: 08 AIRBAG VW51 08 01
Coding: 12344
Shop #: WSC 13765
4 Faults Found:
00532 - Supply Voltage B+
01299 - Diagnostic Interface for Data Bus (J533)
01280 - Airbag; Passenger Side; Disabled
35-00 - -
Address 17: Instruments Labels: Redir Fail!
Part No: 6Y1 919 860 C
Component: KOMBIINSTRUMENT VDO V09
Coding: 16142
Shop #: WSC 40820
3 Faults Found:
01322 - Control Module for Multi-Function Unit (MFA) (J501)
Coding: 00014
Shop #: WSC 13765
3 Faults Found:
Coding: 00019
Shop #: WSC 13765
And AFTER
Tuesday,07,April,2009,15:27:27:46137
Coding: 00031
Shop #: WSC 13765
Coding: 00044
Shop #: WSC 13765
Coding: 09522
Shop #: WSC 13765
1 Fault Found:
Coding: 12344
Shop #: WSC 13765
1 Fault Found:
35-00 - -
Coding: 16142
Shop #: WSC 40820
Coding: 00014
Shop #: WSC 13765
1 Fault Found:
Coding: 00019
Shop #: WSC 13765
What this means is the computer in the pump is faulty. Or at least the power supply to the computer in the pump is. I know I'm talking to a wall here, but hey, has anyone actually tried taking a pump apart, cleaning it up and putting it back on? I'm sure it's just some simple connection problem since the whole thing is all corroded on the outside and probably on the inside due to Skoda's strategic placement of a highly expensive unnecessary part.
Should I give it a go and document it if it works out? Would you like that?
Meanwhile, no more beeps and no more power steering. Just like the old days.
  • 8 months later...
Hi, Did you ever get this fixed and if so would you mind telling e what you did? I have a similar if not the same problem, actually think my pump has died but just trying to explore all the options before forking out all the "hard earned" I was also empathising woth your talking to yourself phase, been there, done that.
