Car Signal Input Octavia
I have a Skoda Octavia 1.9 2006 mod that im gonna install a pioneer avic 900.
I need the car speed signal wire.
Called Odometer
I have a diagram of Kia cee'd but havent found any of skodas. here is the cee'd diagram. know of any like this just for skoda octavia? post it here
Kia Forum
shouldn't this be in Octavia II?
Not if it is/was a taxi, they were until very recently still being sold in the mk1 shape with the 1.9 sdi engine
Skoda octavia 1.9 TDI 06. gues its 2. anyway. noone found that i needed? :(
Not a taxi..
Moved to somewhere more appropriate.
The speed signal in the octy is sent via a canbus data stream to the headunit, its present for all models for the gala function to work.
I dont know of an interface to separate the data out from the canbus, although I assume the requirement on the Avic is optional and it should still work without the signal present.
yes ofc. it works grait without the signal input. but the thing is if i drive trough a tunnel, i will loose my navi signal and dns
This is one thing that seems to be an issue with fitting a non vag navi unit into a canbus car. For example my Columbus (now £650, from ebay) is designed to work with the octy2 and works fine when going through tunnels.
not a problem if it doesent work tho. i just want to have that diagram so i can install it when i have everything else unmounted from the dashboard.
Another thing. is the cd player hard to get out from the dashboard? is it clipsed or u need to unskrew everything? sry for my english
You need to remove the surround and then there are screws located for the headunit behind :thumbup:
