Oil Pressure Switch Location
Hi,
can anyone please tell me where the Oil Pressure Switch is?
I need to change mine...typical idle warning beep etc etc.
If anyone's got the link to any pictures that would be most appreciated.
Many thanks.
Not got a pic but open the bonnet and take the engine cover off.
From where you're stood it is South-east (not too far from the battery) It is down the side of the oil filter ( the thing with the large plastic bolt at the top ) you will be able to clearly see the wire connector attached to the switch.
Easy job and will be about a tenner.
HTH
Which model and engine type?
HTH
Nice one cheers. And to confirm, and MoggyTech question, it's the Fabia MkI 8V 1.4. Is it that same locale?
Thanks again.
whoops I always assume eveyone had a diesel. sorry I may be completely wrong now
Just changed an Oil Pressure Switch on my 1.4MPI, and yes it is to the right of the Oil Filter, just to the left of the battery. I had the Oil Warning Light/Beeps on 2000+ Revs. All fine now!! (it was £11.35 inc VAT from my local dealer)
