rear brake light
my offside brake light has blown! :rotz:
ive had a quick look but cant find how i change them, there are 2 screws on the rear in the boot but i dont think its them i need to remove? or is it a take back to skoda so they can charge you £100 for a bulb jobby??
On Mk1 Fabias you pull back the trim inside the boot and unclip the back of the light unit to access the lamps. Does the handbook not show how to do it?
not checked yet, been out all day.
There is a black plastic screw in the boot , which can be taken off using a coin...
Only 1 screw is fixing the brake lamp. Remove it then pull the lamp body gently, then you can unplug the wiring...
thanks for that, just looked in manual and it does say! in future i'll check first :holmes:
