Removing Rear Lights!
How do you I can see two screws but how do you get too the other two behind th fascia.
Do you have to remove the fascia blocking the screws?
If so how do you do that?
Im swapping my rear lights for somebody else's facelift lights.:thumbup:
Should we keep our own clusters or swap them aswell if they are needed to work with the appropriate lights if they were updated aswell??
remove the fascia, PULL HARD iirc
TWANNNNNGGGGG! (as the clip goes flying into the front of the car :D)
Right just the same as removing the boot fascia to get to the rear washer?
That's if your lucky.. on my last Fabia the clips stayed put and the plastic just gave way on a couple.. nice!
I'm sure yours will be fine though :)
There are screws for the middle fascia is it easier to take that out first?
the ones on the side come away with a pull. To remove it completely you will need to undo the lower screw, but usually just pulling it out can get it out the way far enough to expose the 2 tucked away 8mm bolts.
Ask MikeSM56 how we removed my rear lights.........................
After I have just take all the panels of it just became clear that we both wanted the facelift lights.
So does anybody that actually has facelift lights want to swap for my pre-facelift lights???
I prefer the pre-facelift lights..............thats why i've already swapped :thumbup:
Should've come to me man!
If this doesn't happen for you, you should get some red lamin-x and do a full red rear cluster as I've still yet to see this done!
I was gonna lami-x the top (brake) light on my clusters black to follow the body line from the boot (like on the C-class coupe's, and my Furby's black).. but gone of this idea now.
If i had to do it again, I'd use one of these!
For the sake of my knuckles:D
Yes you can do it whiteout removing anything just a hard job that
Someone has got all red rears as their display pic.
Next time it'll be...........................
http://briskoda.net/members/dayve/ this guy has it as his display image atm.
I'm thinking about total red clusters and and tinted front lights :thumbup:
Fancy helping out mikey boy :D :P :rofl:
Aaaaaarrrrrrrggggggghhhhhhhh....................................
28167.attach
:P:D:rofl::rofl::rofl:
