Help
just dropped a bit of a ******* i was been clever and servicing my own car my octavia vrs and was having problems taking the oil filter off when i put a screw driver straight through it and in to the part where the filter screws on does anybody no what this part is called or can it be patched up
please help
Think your on about the oil cooler. Part number is 028117021K. No idea on cost though.
Sorry to hear that.
It does help avoid mistakes if you can quote the year of your car and engine code (AUQ' etc ) for members to help you.
First time I changed my oil, did same method only at bottom of filter, ended up with hot oil all up my arm, not good.
On a visit to Halfords found that they sell a pressed steel socket that fits tightly on the bottom of the filter body flats.
( its about 74mm across flats with a 3/8" square socket hole in the centre).
Peter
my car is a 2002 octavia vrs engine code is auq something does the part your on about sit fluss when the oil filter is tightened i ended up with warm water on my arm from the coolent that spilt out
you must of gone thru the heat exchanger or a coolant pipe ????
good luck tho mate . if its the heat exchanger it might be xpensive but dont know.
billy
Ive got a 2009 ETKA with some prices attached
Part number: 028 117 021 L Oil Cooler (for AUQ engine)
has a price of £100.50 plus vat
Just checked against your year and engine code, price is same.
Yes it sits flush is squarish with 2 stub pipes sticking out
Sorry mate
Peter
Edited by Silver Bullet
update
Forgot to mention water from the coolent system came out too ive not hit a pipe its definatley not a pipe ive put a hole in where the oil filter screws in
yes its the oil cooler ive damaged im going to buy a new one and fit it today looks simple to fit just 1 bolt holding it in place i will let you know how i go on
Just to let you all know ive replaced the oil cooler today job done car serviced and running like a dream
