N112 cleaning
Hi is it possible to clean the 1.8T n112 valve or what is it? If yes would anyone be able to point me to exactly where it is as I`m not quite sure :confused::o
Why do you want to clean the n112 v/v? It is the secondary air injection solenoid v/v and feeds extra air at start up to warm the cat up quickly.Would not think it should be dirty as it draw filtered air from the air filter box.
I`ve got the P0411 code showing up, as far as I can tell all the pipework should be fine, secondary air pump sounds nice when it`s on so I was thinking maybe the n112 is sticking or something?
Funny thing is everytime I reset the light it always comes back roughly after 3 days? :confused: Why not straight away.
Anyone? Or should I not bother
Before messing with the N112 have a look at the secondary air pump for splits in the two casings which are joined together by rivets. You maybe able to get your finger nail between the casings.
