Windows 7 Media Centre with DVB-S tuners
It works :thumbup:
Well, from what I remember, Windows MCE and XP only ever supported digital terrestrial TV, and satellite support was lacking, no matter what hardware you had, I never managed to get it working.
Well, they've amended that with W7, and it's fantastic. Essentially, I have all of FreeSat, inculding BBC HD fully guided, working and recordable. My PC has just turned into a funky Sky+ box for all Freesat :D with the ability to record, record TV series link, etc. Of course, none of the Sky channels are available, but for everything else, it's brilliant. For the £50 it cost me to get a decent DVB-S2 (S2 gives MPEG4 / HD compatibility), I have full Sat TV, HD with dolby digital come to life :thumbup:
Tut.. have moved your post to the tech shed... you should know better :rofl:
This is good news. the flat im in at the moment only has a single sat connection, so i cant justify paying for a Sky+/HD sub, but i am looking into a decent HTPC setup to replace the rather power-hungry eggbox+pc combo.
IIRC the win7 part of MCE has been back-ported to vista/xp MCE too if you look in the usual places :)
Out if curiosity waht card are you using for the freesat
A Technotrend S2-3200 budget PCI (clicky. It has the expansion slot for the CAM addon. But I wanted to get one that was S2 / h264 compatible for future HD possibilities.
You can get cards with twin tuners and you can gang multiple cards in one system. Some chap has effectively 6 tuners so he can record 6 different programs or record 5 and watch a 6th :eek:
but surely your limited by the number of sat connections? :confused:
Indeed, but an 8 output LNB can be had for peanuts on ebay. Then just run the 8 feeds into your house and its all sorted.
There are some pretty funky systems being shown at NAB for dealing with HD and more which look stunning, but a bit more than the £50 you quote.
What sort of power does the PC have to process it all?
SWMBO's PC which has the card is pretty old. An early X2 athlon, 1GB RAM. I remember it not being able to handle HD very well because of the limited CPU power, but with W7MC, it's running a lot better, presumably because it can offload to the GPU which is a 7950GT so not too bad.
Hmm that's nice to know, might have to look at hunting down a card at some point and having a play
Will have to see how much room I have in my HTPC case.
