Setting Up Fog Lights? Lil Help!
Hello,
Both my foglight were cracked so I got a pair from ebay!
I (stupendously) Played with all the screws on the units before installing them and now it dawns on me one of the screws I twiddled moved the beam up and down!
In Short.. where should they be projecting? Would an MOT centre be able to tweak these as I learnt on a previous post they only check they work on MOT's, not where fog lights shine?
Rob The Stupid :-)
Some garages do have a scale on the wall, so when its parket on the ramp, it tells them where your main beam shines. Not sure if they can do it on fogs as well. If the mot station checks it, they will surely be able to tweak it for you.
Just make sure they shine on the road and not in folks faces and you'll be fine untill then.
