130tdi
To save trawling through everything what does the 130tdi come in, through the range
Classic ambient or L@k, and what problems are associated with them as SWMBO is wanting to change her 130 tdi superb for 1 but needs a bit more boot space, and to tow the house on wheels
IIRC you could get 130PD in elegance and L&K spec and also a special ambiente SE (or something) spec which was a run out model
Agreed, but I'd have thought a Superb would have much the same boot space?
That's its only downfall, due to the rear window boot access is limited, if you had 3 of them large suit cases you can only get 2 of them in, the new hatchback has solved that problem but we would have to wait for the prices to come down a lot
Anyone know where we might find one of the last ones?? have tried auto trader
I've never actually come across one of the Ambiente SE models.
Equally to the point, early L&Ks were 110 5-speed, not 130 and 6.
There are a few 04 plate 130L&K's out there, I looked at one the other day.
I have a 53 plate L&K 130!
The elegance definitely had a 130bhp 1.9TDi engine with 6 speed box option. If you get a later one on 04/54 plate then Skoda put some extra upgrades on these to try and get rid of the old stock. e.g. Black Leather heated seats
Several problems come to mind from my past experience of owning one, CD changer packing up, rear washer leaking into the wiper motor and causing it to jump to life by itself, also the demist function on the climatronic for the front windscreen being pants (not a fault, just bad design). Also the 1.9Tdi lump takes ages to warm up on a cold morning.
IMO the Superb's boot size is more sensible than the Octavia (which is far too big most of the time) at the price of rear leg room.
There is also nothing wrong with the 110, it will probably be more economical than the 130 also (my 110 Elegance Octavia never dropped below 60 MPG average, whereas i struggle to get 50 MPG average out of my 130 Superb).
The only one I've ever seen was a 52 plate, with a 5-speed box and TD(red)i(/red) badge. OK?
Mines a 'T' red 'DI' and six-speed - if it matters!
I take it that's how you can tell its a 130 without asking
Yes
TDi = 110
TDI = 130
TDi = 150 IIRC (used on Golf's etc)
If the original service book/boot sticker is present it should also say 96kW ASZ - the engine power/code.
re tdi
I have a 03 130 tdi elegance estate 6 speed.( Bags of room)Check out the vnt turbo is not sticking.Put it under load going up a steep hill in 6th and see if it goes into limp home mode.
cliver
There are a few 130's out there, you have to bide your time though, it took me nearly 6 months to find mine (04plate Elegance).
My one is a 130 pd with 136 BHP as standard Elegance 6 speed on a 54 plate , and even on a brisk drive of 50 miles i can get near to 58 mpg . , check the turbo , full service history .
Check my sig. I've averaged 50.4mpg since september last year and my driving style/roads are very mixed, mine also has a few little performance tweaks
