Is there a website.....
.....that has fitment details of all OEM wheels for all manufacturers
Having seen the Octavia on Mercedes wheels at Combe and heard that Subaru wheels also feature 5x100 sizing i'm intrigued what else would actually fit.
I googled but couldn't find anything that lists OEM just all the aftermarket options, and i THINK i remember seeing a link here somewhere but i may have dreamt that :rolleyes:
Any ideas?
if it was a mk1 octavia on merc wheels then the wheels would either be replicas in 5x100 fitment or he'd have wheel adaptors.
with the right adaptors you could make most wheels fit.
i'm not sure of sites that list the standard fitments but there will be many out there.
subaru have smaller centre bores I think so actually don't fit over the 57.1mm furby hub.
toyota also have 5 x 100 in a few models but not sure on the centre bore, might also be smaller than 57.1mm. You can go bigger (and make up the gap with spigot rings) but not smaller unless you fancied sticking your hub on a lathe to take off 1.55mm all round to get down to 54mm. :D
Edit: Just noticed impreza is 56.1mm so 1mm too small.
ta both :thumbup:
I did think that if it was that simple how come there wasn't more interbrand chopping and changing going on.
Stupid manufacturers why can't everything just be universal :rolleyes:
Bugger, does this mean, I can't nick my dads gold Speedlines and fit them to my car!! :thumbdwn:
I think the Subaru ones have slightly larger bolt holes as well. The wheel nuts are a 19 mm socket and not a 17 mm on ours.
My wheel nuts are 19mm heads too, but that doesn't mean the thread is different. :) It just happened my "15mm longer" bolts came with 19mm heads.
But for the record, no the speedlines cannot be fitted without some serious machining. However you never know. There "might" be a hubcentric spacer kit out there somewhere which sits over the 57.1mm hub and has the required 56.1mm hub for the speedlines. However I have never heard of such a conversion kit and doubt it even exists due to lack of demand.
