firing on three
I have an intermittent problem with my 02 fabia tdi. Once nearly warmed up it will start firing on3. If you switch off & on again the problem goes. That was up until last night & again this morning when the problem became permanent. I had been told some time ago that it could be the injector loom in the rocker cover. I took the cover off, but could not work out how the connectors came off. I poked around and gave all the wiring a push into the connectors, put it back together, and now it is fine. My worry is for how long. I am in france and regularly drive back to the UK. Has anyone had similar experience or suggestions please?
welcome to briskoda.
For a answer to your question I would stick this in the Fabia 1 section.
welcome along, best post in fabia section for a faster response :thumbup:
Welcome :)
