Non-standard brake hoses - where from?
I have a requirement for some brake hoses for a conversion I'm about to do on my Octavia II.
As I'm in a cast at the moment and can't do any work on the car (I can't even bend down to have a good look!) can someone tell me if the fronts have 4 hoses with a hardline connector or just 2 that go from body to caliper?
I need a suitable hose with a 10x1mm 90 degree fitting on the caliper end.
Thanks in advance :thumbup:
Should be just a single flexi hose from a connection point on the body to the caliper.
Excellent, thanks Ross. Do you (or does anyone) know the correct length? I'd go and measure mine but pretty stuck at the moment.
