dye in the coolant??????? hmmmmmmmmmmmmm
Got a leak and my mate is a mechanic. He said he'll find it by dropping a dye in the expansion tank and using a ultra violet light to trace the source.
Anyone used this method..................
it should work, but be carefull. Water has a habit of appearing to come from somewhere, where in reality it came from somewhere else.
Unless it's leaking inside the engine ....in which case you wont see it
its got to come out from somwhere though if its leaking
No. If, for example, the head gasket is leaking, the cooland leaks internally into the engine, and disappears as a bit of steam in the exhaust.
If the oil cooler leaks, the coolant vanishes into the oil- though it would show up as mayonnaise.
It's more likely you have an external leak though, so the test is worth doing.
Yeash as I can see some pink residue near the back of the exhaust shield
a similar method is used for finding leaks in aircon systems
g12 coolant has an ultraviolet additive in it anyway ;)
Well its no good to me as I doubt I have any coolant in there. Keep having to top it up with water.
No point in buying coolant for it to leak out
