Led bulbs on sides?
I've tried to fit w5w led bulbs on sides but they don't work, they come on for few seconds and then go off.
Anyone knows a solution for this?
Or maybe there is another way to change yellowish bulbs into xenon/white look?
Once led bulbs are fitted I assume there will be a warning light coming up saying that the bulbs are burnt - is there any way to override it using VAG COM?
You will probably need a resistor to fool the autocheck system into agreeing that there is a bulb in there. Or you can buy bulbs with the resistors already in.
Any idea where I can find such led bulbs with built in resistors?
It looks awesome but £50 for 2 leds is a bit steep for me ;-)
I think I'll go for a pair of ceramic load resistors
E-ZEE SISTA - Lo Heat LED Load Resistors - Best for OBD on eBay, also Bulbs Lenses, Lights Lighting Accessories, Car Tuning Styling, Cars, Parts Vehicles (end time 23-May-09 22:50:26 BST)
They should do the trick from what I've googled out.
I was lucky I had them for £20 in a group buy with the Seat lot. I wouldn't pay that much either
I've just fitted those ceramic load resistors and the job is done, very pleased with led sides now :-)
