Fuse box cover
I wanted to check the fuse for our caravan feed and could not undo the two clips which hold it on. It shows an arrow for releasing lid but it was solid and i did not want to use brute force in case i broke the clips, futher more the sliding clips seem to be held in by slots in the case. Can anyone explain what way :thumbup:i can get it off. Cheers.
If its the one under the bonnet you have to be quite forceful with the clips. I think you push the 2 latches towards the padlock symbols to open it. It is waterproofed as it directly underneath the bonnet gap to make sure it is secured properly once you have checked your fuses by ensuring the locked padlock symbols are visible again.
Edited by dstev2000
crap typo.....
I left skin behind trying to open those. They gave up eventually, but not without a struggle.
