throttle body reset
As above, anyone know how to reset the TB?
Gonna take mine out to clean it, and I've heard they can be reset to match the map you are runing on the car...
or am I talking b*ll*cks?:D
ideally yeah, some people seem to say it can be done by removing the battery then reconnecting, but i just took mine to a stealership and got them to do it
You don't need to reset it at all if you don't disconnect it from the electrics, and you don't need to disconnect it from the electrics to clean it, so that's that one sorted then :D
You just need to take the body off the manifold, and the hose off the body, and give the body a good squirt inside with carb cleaner/WD40, rub it all clean, and get a mate (or a brick) to hold the accelerator down to open the flap and get around that so it's super clean. :thumbup:
Hope that helps
make sure when using the friend (Brick!) that you use a tooth brush to clean the throttle butterfly, as if the friend (Brick!) slips it hurts like hell!!!!! not talking from personal experience but have seen the cutson someone else.. Ouch!
a job for my next days off then...
(in between cleaning the wife's Ibiza which is up for sale, and rebuilding the Clio/changing the cambelt:lol:)
