radio aerial in the way
I've just fitted roof bars to my octy 07(Hatch). These are to carry a fishing kayak. The problem is that the aerial at the end of the roof is going to be flattened by the kayak itself which will probably damage it. Is there any way of bending/detatching this aerial whilst the kayak is mounted onto the roof bars.
Unscrew the top part of the aerial - it won't unscew entirely or fall out; fold it flat then screw it in again.
Done!! Thanks a mill
Great help as usual
Great help as usual
You're welcome - glad it worked. BTW if you want to remove the top part of the aerial completely, give it a very hard, sudden tug after you've unscrewed it to the point that it rotates freely. This can be quite scary as the roof panel bends! It's apparently an anti-theft precaution so that the aerial can't be removed too easily.
Wedge the key blade against it using your thumb as a support, like opening a beer bottle. I've pulled to the point of almost falling off the car, and nada.
How much were the bars if you don't mind and are they Skoda OEM ones?
Carl:thumbup:
As i'm from the emerald isle I got them from Micksgarage.ie. They cost 120 euro approx, ordered them online and arrived in 3 days. They're not skoda parts and they attach to the underside of the roof by the door openings. I think they're italian and called La Prealpina. Not too difficult to asemble and sturdy on the roof. I think the genuine skoda rails attach through a bolt hole above each door but I would have paid a lot more than 120 euros from the local dealership.They should also be relatively easy to detatch when not needed.
They should be plenty strong enough to carry my fishing kayak which is getting dipped into the sea this coming weekend
Careful not to put dents in the roof though, don't overtighten it. Put some felt or rubber on the *clean* pads and roof to prevent scratching too.
Will do. Thanks
