VCDS read fault codes - help needed
I have the fault codes read with VCDS. I need some help to interpret them and find a way to solve the problems:
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001417140
Coding: E18A8D030004140000110D000000000000087F075C
Shop #: WSC 17027 576 15979
Part No: 1Z2 955 119 A
Component: Wischer SK351 012 0401
Coding: 00065525
Shop #: WSC 17027
Part No: 1K0 955 559 M
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 17027
3 Faults Found:
02403 - Terminal 15 for Interior
012 - Electrical Fault in Circuit
02402 - Control Circuit for Terminal 15 for Interior
010 - Open or Short to Plus - Intermittent
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
Address 46: Central Conv. Labels: 1K0-959-433-46.lbl
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: E1C802007F2D8505485F861004
Part No: 1Z0 951 171
Component: Innenraumueberw.005 4801
Coding: 00000000
Shop #: WSC 00000
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Component: NGS n.mounted
1 Fault Found:
01134 - Alarm Horn (H12)
014 - Defective
The first set of faults are all related to the rain sensor wipers, looks like there could be a bad connection somewhere.
The second fault relates to the alarm sounder having failed.
That seems to be right as I can't get the alarm to work, it only blinks with lights but there is no sound when it's activated.
Do you know where the alarm horn is located? Is it easily accessible? Can I replace it myself or is the visit at Skoda dealer necessary?
I'm a bit crossed in regards to rain sensor wipers as they the wipers automatically switch on when it rains, didn't notice any fault with them.
I think the alarm horn is located in one of the front wheel arches but I'm not entirely sure. I've never had to touch it so I don't know how to remove it or how easy a job it is. I'm sure someone else on here should be able to tell you or correct me if I'm wrong.
As to the rain sensor wipers, the fault is intermittent supply voltage on terminal 15. If they are working, I would recommend you clear the fault code and see if it comes back.If it does its likely you have a dodgy connection somewhere. The errors you have aren't on the Ross Tech Wiki so I inferred their meaning from my limited knowledge of the German language. Wischer = Wiper - RegenLichtSens = Rain Light Sensor
Yes, the fault comes back once the codes are cleared.
Where can I find terminal 15 to check the connections?
Do you actually have the rain and light sensor as both of those faults together suggests that there might not be a connection and perhaps the car is badly coded.
When it starts to rain the wipers are activated and when it's getting dark the lights go on so I think I have the rain and light sensor fitted.
I own a HEX+CAN interface, is there any way I can do some diagnostics?
Have you cleared the faults and see if they return?
Yes, couple times.
I've also noticed that when I push the instrument cluster in there is a warning sound and few lights come on for just a second or so: abs, assisted steering, exclamation mark light. And then the airbag light remains on all the time until I clear the faults.
Does it mean the instrument cluster plug might be loose? How do I sort this out?
Any ideas?
