Found the bugger. Coolant leak
Finally after using some rad dye, it stood out a mile.
Fabia 2005
part 6 on the diagram.
Costing me £44 for the new pipes and seals.
Well done. :thumbup:
Cool. Any idea why it failed?
There was a tiny crack near the weld where the two pipes are held together.
Has been driving me crazy. My street was illuminous before where I emptied the system and flushed it out.
How much g12 coolant do I need now to fill back up?
3 litres should do it at a 50/50 mix with water.
Ahhh she was a bugger to fix but she's hunky dorey now!! About time, getting sick of hauling a water bottle everywhere I go :D
Old thread alert! However I have this issue, did you notice it leaking INSIDE the car also? Was the carpet wet on the passenger side or anything? Not sure if it would do if a dash etc was in.
However im loosing coolant left right and centre, looking at your picture it seems dead on what I can see, but mine is also leaking inside the car, not just out!
How did you fix it? Case of ramps and new parts? and elbow grease?
