EPC Light On!
I've had a quick search but no luck!
Basically my EPC light came on during my drive home, its a 2004 Fabia vRS, any idea's what it may be, if so is it costly?!
Thanks in advance:thumbup:
I've managed to reset the fault now. Any idea's what it could be?
What was the code that you cleared?
I didn't clear it with some software, just the same you clear the service indicator. Sorry forgot to mention that. Do you think i need to check with vagcom?
Probably a good idea.
You cant clear anything other than the service light by that procedure so either its an intermittant fault or its still got issues.
Thanks Lummox, any ideas where to look if its an intermittant fault?
I'm going to do some fault finding as I dont have access to Vagcom at the moment
I'd the best way to fault find is to start with VAG-COM - otherwise "where to begin"!
Ok, i've travelled to work this morning, car seems fine, but the light came back on again! So has anyone got vagcom in the chester/ northwest area, there's a couple of beers in it for you!
