Just bought one of these
Out of the frying pan and into the fire :)
Hope it works out ok :thumbup:
:thumbup:
So do I this time,
does anyone have one of these fitted, and what maps can be used in them, could the speed cameras be put onto the maps????
Loving the "RARE CAMERA" option in the GUI :)
Looks okay. you'll have to do a review. I believe you'll have to get a seperate TV aerial.
It comes with one, but I think if i can get a combined aerial it would look a lot neater, I am going to have to change my radio one as the amp is on the blink due to water ingress
So does anyone know where to get a combined one from or what type will work
Ooops..look at the feedback..lots of items 'private', and when did you ever see the same name so repetetive..wouldn't have touched that with a barge pole..hopefully you will prove me wrong :thumbup:
Will I need a wiring connector to connect it to the car so that it turns off when the ignition key is removed, also for connecting the sat nav to the rear abs sensors, and can you get a push in areal connector to replace the clip on one????
Will the dealers have what I need or can you get them cheaper??
Edited by skippy41
Right where to start, it came with loads of wires, only the bit that plugs into the set had the plug on it had to get a BMW converter and the guy at the garage wired the loose ends into it.
next job is to run a wire to the aerial amp so that the can bus can be over ridden, the radio works but with no sound until thats done, SD play OK and mp3s from SD cards, DVD works well.
sat nav we followed the instructions in the guide from here and stuck the sat aerial to the alloy cross member it started to work then all of a sudden for some reason its coming up the card is wrong and its not picking up the Sat's any ideas anyone??? its tom tom V6.
Having checked back on the thread alternative to mdf2 it has the same screen set up as the Winston but without the ease of fitting
Is there a way to connect the live so that the ignition can be turned off but will turn the unit off when the key is removed??/ It has to sit with the ignition lights on at the moment
No, not that I know of. I think you're going to have to choose power to it all the time or power to it with the ignition on.
I need to get the sat nav up and running but when I touch the sat nav button it comes up with gps program does not exist please insert correct SD card??? there is only one and it can only go in one way terminals down, as I said it looks like the Winton unit but without the edges anyone any ideas ??????
Right I have contacted the seller via Ebay, and told him about the problem , he said what I thought the card reader is not working, so i told him its coming back for a refund.
Please could someone provide a list or links to, of all in one units that just swap over and work,with can bus, I need radio sat nav and blue tooth anything else will be a bonus
