Which Dodo Wax?
I normally use Collinute 476 on my Sprint Yellow Fabia vRS - I'm very impressed by it - but I've got a couple of sample pots of Dodo Wax so I thought I would give them a trial over the summer and then get the Colly back on for winter.
The sample pots I've got are....
  • Dodo Juice Banana Armour - a hard wax
  • Dodo Juice Orange Crush - a soft wax
What are the pros and cons of soft wax vs hard wax. Should I choose one or the other, or can I try layers of each, and if so which should go on first?
Your thoughts please
If you want to use it up, I'd go hard as the base coat for a bit of durability, then the Orange Crush on the top. See what the finish is like :thumbup: I still need to be convinced about Dodo as a brand ;)
Depending on time available I'd then do a couple of coats of Orange, an hour apart.
Did you end up claying tonight?
Steve
Steve
Yes - I gave the car a wash down wih some IPA and then Virosol - and then after rinsing I used the soft Bilt-Hamber clay.
Had a quick test on a small section of the works van (10 years old and not very clean) and it removed loads.
Did my car and it didn't pick up too much - but thats more because there wasn't much to take off anyway I think.
If it stays fine on Saturday, the plan is paint correction with my Kestrel DAS-6 and the Menz polishes, followed by Poorboys EX-P sealant and then the Dodo Wax(es).
Like you I remain unconvinced about Dodo - although its more a feeling that they are overpriced rather than not very good. Will see what I think when its done.
Sounds like a plan :thumbup:
Current forecast doesn't look brilliant for the w/e, down here at least :(
But fingers crossed!
Steve
I've just been getting some Dodo, Hard Candy & Purple Haze. As Wardy said I went Hard (2 coats) then soft (2 coats) All at least an hour apart. Initial impressions are very good. Very easy to apply and remove. I don't know how it will work on Yellow but on Black the hard gives a crisp shine & soft gives kind of wet, deep look. I went for these two over the alternate wax I was going to get (Zymol Titanium) because they were out of stock on Zymol and at double the price of the Dodo I'm kinda glad I went Dodo.
Oh yea they smell really good too.:D
Here is a pic with it on mine, obviously no comparison to yellow but hey I'm pleased,
Nice finish, but still think Blackfire Midnight Sun takes some beating on Black Magic :cool:
Steve
Bit late on the response here but I would go with Wardys and JohnRS's recommendation's, get the hard layer on their first and build up your soft layer on top.............:thumbup:
Do you have some nice Spray Sealant to go on top as a final LSP as this will make the world of difference to the look...........:D
Bit late on the response here....
I posted after 11.00pm last night, so I think I can put up with a reply by 9.00am next day. I assume even detailing gods need their sleep ;)
I was going to seal with Poorboys EX-P after the polish stage. Can I also use that after the wax? Or I could try the Megs Ultimate Quik Detailer that I picked up in the US? Or would you suggest something else?
:thumbup:
A run around the car with the Megs UQD will do the job nicely mate...........:thumbup:
Then everytime you was the car just run around with the Megs UQD to top up that protection, that's what I do and mine looks OK............:P
i use both mate,
limed
banana then the orange:thumbup:
ive always been a fan , also been known to chuck some redmist over but i found its can be abit greasy and anoying to get off :mad:
Edited by Lloyd55vrs
I agree with that LLoyd, vRS_Si let me try some at Castle Combe and it was very greasy, too greasy in fact..............think I will stick with some other products............:o
The last time I did the Furby I used the following:
Sonus Green clay
megs #10 showcar glaze
Poorboys EX-P 2 coats
Banana Armor
Petes 51
Vic wax Concours
Sonus high gloss caranuba spritz
Then I busted the ankle and haven't touched it in 6 weeks :( I'll let you know how it washes , its sat covered in crap from the neighbours budleigh(sp) and hedge atm)
As for the Dodo banana Armor I was not that impressed by its longevity from when I first used it, and since having it a while it as broken down and separated quite considerably in the pot. If you like it I would advise buying the smallest pot available.
