tfsi brake pads
Can't see why they wouldn't fit, they have the same braking systems.
Yep, they'll fit. Not that keen on EBC pads after bad experiences with their Greenstuff range. The reds are supposed to be better though.
Here you go, filtered results for the 2.0T. I've used this site for EBC discs before and would recommend the service:
http://www.ebcbrakesdirect.com/car/parts_pad.asp?part=pad&make=SKODA&model=Octavia&year=2.0+Turbo++(inc+VRS)+(2006-)
I'd go for Pagid, Mintex or Tarox though personally, if DS2500s weren't available, which are my first choice. What do you consider 'resaonble' to pay for them?
Steve
Our good friends at JKM, DS2500s at £96 inc VAT:
Ferodo Brake Pads - SKODA
To me, that's a good price. Depends what your outlook is :)
Steve
cheers, thats a very good price - i hadn't seen them much under 115 anywhere
I've got a set of brand new boxed EBC Redstuff Ceramics here going spare if you are interested.
"Front Brake Pads -
Please Note: No pad sensor wires. OEM sensor requires by-passing."
is this done via vag-com, or does it require a physical workaround when using the ds2500 pads?
It can be turned off with VCDS or it may be possible to short the pins on the pad wear sensor to remove the warning.
