Tyres
I will be needing a set of tyres on my Octavia Scout Diesel in the next few months and was wondering if it would cause any problems fitting 225/45/17 instead of the 225/50/17 that came as standard as the price of the 45 profile is so much cheaper than the 50 which seems quite rare. I would be replacing the full set.:chicken:
You may find that it would throw your speedo out since the rolling radius will be different.
don't do it , it may only be a small chainge but it will affect your trip distance, abs, esp, speedo all by only small amounts agreed, but combined , who knows,
i chainged all four two month's ago and fitted michalin ,glad to get rid of dunlops !!!
Stick with 225/50/17 as the 45's will have a slightly harder ride. Plus as said above.
personally id say do it, if you work out the difference its really minimal
Anybody got recommendations of tyres available in 225/50/17 ? I was looking at all season tyres, and so far the Goodyear Vector 4 seem to fit the bill, but it is going to be a big bill :(
I like the look of the Quatrac tyres but they are not available in 225/50...
Try plugging some numbers into this tyre calculator
There's an almost an inch (22mm) difference in diameter (a fraction less if you can find a "big case" 225/45x17)
Your speedo will read even wronger than normal but you can fix that with VAGCOM/VCDS.
The engine will be revving quicker in top gear which will use more fuel but lower gearing might be a good thing if you use the Scout off-road a lot.
The shorter sidewall will be a bit more susceptable to damage but the car will feel a bit more planted.
Hows the price of 235/45x17 in the UK? Scout is 17x7 isn't it? So they should be OK
