Fabia reversing bleeper
How can I turn this nuisance off ? It's driving me mad.
Pull the connector of the "speaker" ?? Can be accessed by bending out the trim on the B-post..
Many thanks for the tip!! (what is the B-post?):thumbup:
I forgot, you call it a pillar.. The A-pillar is the part of the cars body/steel structure on each side of the windscreen, the B-pillar is the one the driver/front passenger safety belt's upper and lower mount is bolted on. The C-pillar is the one behind the rear doors etc,etc..
Pulling of the connector will make the parking help ECU store a fault code, but that is nothing to worry about.
If the parking assistance on your car isn't working properly I'm sure a dealer could have a look at it and fix it for you? I have changed 3 of the sensors on my car, so I know how anoying the "beep" can be when it's not working the way it was intended..
Hope you get it sorted!
Go to the dealer, there has been a recall for the reversing sensors, there is a software fault with them.
