Problem code p0411
I've got this code that keeps coming up could this be the air flow meter? As it says incorrect flow detected (secondary air injection system) I've got a neuspeed air filter with heat shield round it. Would this be causing any problems do you think?
Is the hose (plastic pipe about 1" in diameter) to the air pump still connected to the filter some how?
just checked and all pipes in place and that pipe is connected to the oil breather filter. Spotted another sensor just down from the maf sensor under the plastic engine cover could this be owt?
If you have lumpy running when first started it sounds like the secondary air pump casing has split which can be bolted back together instead of the rivets.
  • 15 years later...
 Якщо насос розколовся, чи може він видавати таку помилку?
Sorry, dont know...just providing translation...
