Front Wishbone Bush
Need to replace passenger side front wishbone bushes as bit worn.
I will be replacing both sets on the front.
Which is the best replacement type to get?
How much and where is the best place to get such items.
Finally am I right in thinking the following are the correct part numbers for the wishbone:
1J0407181 and 357407182
cheers:thumbup:
cheers:thumbup:
Just checked numbers for a 01 and 05 reg vRS, they are as follows:
1J0 407 181...... Bonded rubber mounting (Rear) (As you quoted)
357 407 182...... Bonded rubber mounting (Front) (As you quoted)
Most people seem to get best results by replacing using the following :-
Audi Rear Bush (Solid construction with no cut/outs) and
Powerflex replacement front ones.
Peter
Thanks for the replies:thumbup:
After doing a search on the rear wishbone bush I have decided to go with the audi solid type bush.
I have picked up some audi tt rear bushes + associated bolts etc from TPS this morning and have ordered some powerflex front bushes from Awesome.
Will have fun fitting these this week along with some zero sixty front discs + pads:D
