Door card Reinstallation/Central Locking.
I never seem to get answers with my problems!
So please help!
I tried to install a Rclick RE60 keyless entry kit but it wouldn't work when I followed Jon's instructions. :rolleyes:
I've disconnected everything and everything is back to standard and well insulated.
But my central locking no longer works from either the passenger or drivers door, the boot however does still lock by the central locking and if you hold the key in the slot the windows wind up and down as they should.
Also as I took my doorcard off the drivers side, I can't get it back on!
Maybe the kit doesn't work as I've upset the central locking.
I did have the battery off, but when I put it back on experimenting I blew a Blue 15A Fuse.
The problem I'm having is when I hook the loop on the end of the door pull and put the doorcard back in position the door won't open, it's as if the wire to pull the lock free isn't tight enough for the handle to function, this is the problem I'd most appriciate to be fixed along with the above!
It sounds like you might have done what I did and hooked the hook without clipping the collar into its slot, meaning it has nothing to lever against.
Genius, there is a little collar which the cable fits into next to the hook on the lever, I worked it out myself but much thanks for reply, SPOT ON! :thumbup:
