How to empty fuel tank
Like a daft T---t i put £20 orf petrol in the furby TDi tonight, I havnt run it, What is the easiest way of emptying the tank, as i cant get the tank of on the drive
cheers steve
pump it out at the filter, i was always brought up on the understanding that a drop of petrol in diesel does it a bit of good, i used to put 15 pounds of petrol into my vrs then fill her to the throat with derv, but now our petrol station has performance diesel so never looked back? might be a bit harder to start with the petrol in it, if you got 10 litres out and filled her with diesel
Ive tries syphoning it at the filter but it wont come out, ive even tried at the pipe conection in front if the tank. When i put the ignition on it pumps for about 5 seconds, but then stops
Not sure on the Fabia, but under the rear seats is often a cover, which when removed gives you access to the tank sender unit. My mate did the same on his Laguna and we pumped the fuel out with a hand pump with the sender unit out.
Silly question, but if you haven't run it, how did you get it home from the garage?
Or if you know you put 20 quids worth in, how do you know?
Hmmmmmm.
Bloke in petrol station said "£20 of unleaded sir" I said no diesel, he says would you like me to give you a hand pushing it off the pumps? cos u just put petrol in it! DOH
Towed home, by the bloke i was on the way to visit
Got it out in the end, by 529 turns on of the ignition, All the 5 second bursts of fuel from the tank have emptied it. Just got to get a filter tomorrow and a tank of diseasel
.... and a jump start at a guess.
Bugger, Eh?
Give it a dose of millers, and drive it like you stole it for about 20 miles ( and a new fuel filter to be sure ).
Worked for me.....:o
I worked in a petrol station afew years back. I was normally locked up in an office for 7 hours of the day and i still saw this happen loads!
Guess im tryna say; if your kicking yourself dont . . . . loooooads of people do it!
Will find out in the mornin
Its the first time ive done it in 25 years, worse thing is our lass telling everyone and taking the pi55 on fecebook
Yeah, theres having a laugh and taking the p**s!
I understeered in the wet and caught a curb awhile back. It was nothing major and was sorted a day or two later . . . yet there's an a**e who just wont let it go in work!
Hopefully she loves you and stops soon! :rofl:
It will never stop, i dont give her ammo very often. car now sorted, new filter new fuel, goes like **** now
Real easy way is to take the supply line of the filter and put 12v to the pump, away it goes.
Hello,
Maybe the day will dawn where a fitted chip inside the vehicle's fuel filler pipe will, detect a chip fitted to fuel pump nozzle to withold or release fuel into tank. ??
Ian. 24/06/2009 :rolleyes::D
Hello,
There are such devises out there. Ford have one on there new cars that will only accept a diesel nozzle and there are several after-market devises to prevent miss-fuelling. See:
Fuel for thought | Products | Auto Express
and
Fuelsure | Products | Auto Express
