pop out cup holder
hi can any1 point me in the right direction as how to fit the pop out cup holder in to the dash of my fabia, or a link to a guidew if there is 1, i had a search but came up with nothing,
thanks in advance!
Using a suitable plastic trim removal tool.
1. Remove left hand switch blank (Heated passenger seat switch) this will reveal a torx screw.
2. Carefully remove heater controls fascia unclipping all the way around, This will reveal another torx screw.
3. Unscrew both torx screws and retain, The infill trim to the left of the stereo can now be removed (pop it in the glove box, Just in case you ever need it)
4. Remove cup holder from plastic bag and insert in hole in the dashboard left from the removal of the infill piece.
5. Using one of the torx screws, Secure the cup holder at the bottom, Then open cup holder and secure at the top using the other torx screw.
6. Carefully refit Fascia plate and switch(blank).
7. Sit back and admire your work.
Simples!
thanks mike although what would be a good tool to use to get them out, dont wanna use a screwdriver as dont wanna scratch the plastics cheers
liam
Old credit card works well, if there really tight use two credit cards and put a screwdriver between them to lever it out
I carefully use a dinner knife for this kind of thing normally :)
thanks guys for all the help, am attempting to fit today!
