Air Con feeble
Had air con on today for first time for a long time. Fan on 2 & 3 speed settings.
Output to the fascia outlets barely chilled, improves slighthly when air directed to footwells. In the past it has noticeably chilled the air.
Any ideas ? Any indicative noises I should be looking for ?
Had timings belts and pollen filter replaced earlier in year.
Nick.
i think your air con needs to be recharged :D
costs about £30
Sounds like a recharge needed mate.
My aircon is never off!
Ive never found it to be superb aircon personally. But it should "cold" if not "icecold"
When was the last time the air con was recharged?
To my knowledge, never.
From new, the 1.4 16v saloons done 40000 miles in six years.
Nick
Cheers D.
That's one heck of a coolant loss rate. Not even cheap domestic friges lose fluid at that rate - my last one lasted 20 years. Presume that the car piping relies on compression joints and that this accounts for the loss rate?
One wonders how HMG DOT type approval is maintained, Montreal Protocol applying, in the face of known rates of loss like that ?
If I understand it then, the coolant actual provides the lubrication for the pump. So if you've lost most of your coolant and the coolant contains the pump lubricant (No separate ball race for the compresssor vane spindle), then, unless the compressor is at the bottom of the system and both ends of the compressor vane spindle, are submersed in a sump, which the pump pick-up can't draw-off (Unlikely), then as a minimum, when the engine is on you'll get compressor vane spindle to spindle mounting contact and wear, if not compressor vane to casing contact - Presume the former is near silent, whilst the later must make a hell of a din.
I take it that the compressor vane is always rotating as its spindle is driven from the auxillary cambelt which cannot be disengaged. Presume that the aircon button on the dash board operates some sort of solenoid controlling the fluid flow. ?
This sounds like a lovely bit of value-engineering/planned failure, ensuring that once the system has lost coolant, at a minimum the spindle and its mountings will have been worn. So if you refill- the system, the compressor will have only a limited life thereafter, as the mountings, which are probably non-removable from the casing, will have worn and the spindle will be running off-centre and in unhardened metal, eventually seeing the vanes connecting with the casing. New compressor £800 ?
Modern central heating system pumps work in the same way, but the consequential cost of fluid loss there is usually protected against by boiler integrated safety systems i.e the pump bypass circuit and overheat sensors. And a pump swap-out only costs £40.
What price a peltzier based cooler ?
Funny, it was perfectly OK last year. before it went in to the dealer for the cam belt change.
Nick
Edited by Clunkclick
According to this HJ post the Fabia Air con compressor is the Clutchless type i.e always engaged and when fluid is lost the compressor wears.
Skoda Fabia - 00 1.4 Diagnosing aircon-pitfalls : Motoring Technical matters forum
As I was advised that the ECU had been flashed with an update at the last service, it may be worth my while to get the VAG com out to see if the error code is present !.
You never know
Nick
Mine was empty this Spring, but has been fine since a recharge (touchwood!)
Nick
Unless it's a severe leak, compressor wear is prevented by low pressure cut off. The remaining oil in the gas, is used to keep the compressor lubed. Compressor damage is usually caused if too much water gets into the gas. The glycol based oil turns to acid, which wrecks the compressor.
Moral of the story, have aircon emptied and held in deep vaccum for 45 minutes, then re-charged every 3 to 4 years. It's a no brainer really. £50 for an aircon service, or £800 to have it repaired.
Thanks for the responses.
I'm a bit more confident now, as my air con was producing some chilled output on Monday, so perhaps there's enough coolant there not to activate the cut-out and keep the compressor lubed.
My researches indicate that HMG passed legislation in 2008 further restricting the acceptable limits of losses from these systems, so hey-ho, perhaps this problem may become a thing of the past, or at least one which only needs to be addressed at a longer interval.
Does anybody know whether the illuminated dashboard air con button is supposed to flash in case of malfunction, 'cause I seem to recall that mine did, a little while ago, and, not realising the possible significance I put it down to a short in the switch.
http://www.r744.com/news/pdf/http___www.r744.com_news_news_ida151.php.pdf?PHPSESSID=cac1140e63119d31ad70274159c32427
EU sets car-makers new deadline for greener air conditioning | Environment | guardian.co.uk
Lets hope manufacturers do away with compressor & gas systems and switch to a Peltzier system with all the cost savings and respect for the environment that design represents.
Nick
The VAG COM scan. Is this an indication of an out-of-coolant event or a false error report ?
22:26 03/07/2009Thursday,02,July,2009,09:19:51:08693
VCDS Version: Release 805.4
Data version: 20090602
Nick
Chassis Type: 6Y - Skoda Fabia I
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
VIN: Mileage: 66350km/41227miles
Address 01: Engine Labels: 036-906-034-APE.lbl
Part No: 036 906 034 DF
Component: MARELLI 4MV 5020
Coding: 00031
Shop #: WSC 00000
SKZ7Z0B1485705
1 Fault Found:
18020 - Engine Control Module Incorrectly Coded
P1612 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 6Q0-907-37x-ASR.lbl
Part No: 6Q0 907 379 H
Component: ABS/ASR 5.7 FRONT V20
Coding: 00124
Shop #: WSC 13765
No fault code found.
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Y0 820 045
Component: Klimaanlage X0830
3 Faults Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-10 - Open or Short to Plus - Intermittent
41-10 - Blocked or No Voltage - Intermittent
29-10 - Short to Ground - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 17418
Shop #: WSC 25040
1 Fault Found:
01054 - Power Supply Relay; Terminal 30 (J317)
28-00 - Short to Plus
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 601 C
Component: 02 AIRBAG VW51 0004
Coding: 12338
Shop #: WSC 13765
Address 17: Instruments Labels: Redir Fail!
Part No: 6Y2 919 880 B
Component: KOMBIINSTRUMENT VDO V12
Coding: 16442
Shop #: WSC 25021
SKZ7Z0B1485705
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 33 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 13765
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00140
Shop #: WSC 13765
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 31 Komfortgerát 0001
Coding: 00067
Shop #: WSC 13765
Part No: 6Q2959802
Component: 31 Tõrsteuer.FS TFK 0002
Part No: 6Q2959801
Component: 31 Tõrsteuer.BF TFK 0002
End ---------------------------------------------------------------------
Looks as if I've had a bit of the spontaneous self-recoding here - red highlight and some of the pre-existing fault codes have changed - orange highlight.
I believe 00071 is correct for my Fabia, 1.4 16V 100BHP ABS, Airbags, Aircon.
But earlier scan in November 2008, shows 00071 as opposed to the current reading of 00031.
Nov '08 scan below:-
VCDS Version: Release 805.1
Data version: 20081017
Nick
Friday,21,November,2008,20:36:31:08693
VIN ******************** Mileage: 62130km/38605miles
Component: MARELLI 4MV 4842
Coding: 00071 Shop #: WSC 25040
Readiness: 1110 0101
Coding: 00124
Shop #: WSC 13765
3 Faults Found:
28-10 - Short to Plus - Intermittent
Coding: 17418
Shop #: WSC 25040
1 Fault Found:
Coding: 12338
Shop #: WSC 13765
Coding: 16442
Shop #: WSC 25021
Coding: 00014
Shop #: WSC 13765
Coding: 00140
Shop #: WSC 13765
Coding: 00067
Shop #: WSC 13765
Part No: 6Q2959802
Part No: 6Q2959801
And guess what - the cars had a major service at a Skoda main dealer between Nov '08 and July '09 ! And it doesn't look like any of the existing faults were addressed, even though I was told the ECU software was updated on this occasion.
Looks as if this is quite a common problem:-
http://www.ilexa.co.uk/forum/index.php?topic=13169.0
From the above link :-
000?x: CAN-Datenbus Teilnehmer
+1 - ABS
+2 - Airbag
+4 - AC
1+2+4 = 7 => 0007x
000x?: Getriebevariante
1 - 5-speed gearbox
00071
To get 00031, you just omit +4 for AC - that's pretty powerful re-coding ! Chances of that happening randomly ?
Nick
