side windows squeaking, creaking
Hi there,
I have an Octavia II 2005, side windows are squeaking when left down/lift up.
Have you any ideea how to oil that?
Many thanks.
I have a similar issue, especially when it is hot! mine gets less noticable when the windows/car have been cleaned. I was gonna (havent yet) clean the seals (inside lips) first.
The sound is coming from down inside side somewhere. I cleaned up the lips but is not solved. I need to put some oil inside on the lifter or bearings !
Mine has started to rattle a little when put up, goes away after a while. Think it needs some lubing of seals due to hot weather.
I had it, Skoda garage sprayed some lubricant in the "rails" (hope to explain myself) and things improved.
