What is the correct tyre pressure?
Hi All
What is the correct Tyre pressure for my tyres?
I have a skoda elegance with the standard 17" alloys.
Thanks.
Generally 32 psi is about right, 34 if you are carrying stuff in the rear.
front= 36 psi rear= 32 psi. skoda recomended tyre pressure for 225/45/17 tyres.
The correct pressures are provided on the inside of the fuel filler cap.
I believe these are for 17in:
- Light loads
34psi /2.3 bar front,
30psi/ 2.1 bar rear,
- Haavy loads,
37psi / 2.5 bar front,
44psi / 3.0 bar rear
For 16in, the pressures are even higher:
- Light loads
38psi /2.6 bar front,
35psi/ 2.4 bar rear,
- Haavy loads,
43psi / 2.9 bar front,
50psi / 3.4 bar rear
This is for 2.5TDI V6
