Washer jet not working
The front washer jet on the drivers side on my Mk1 Octavia vRS estate isn't working.
The passenger side works fine. I've tried unblocking the jet but stil nothing, theres not even a dribble of water coming out.
Any ideas?
Thanks,
Assuming the tubing is still attached, jet completely blocked, or blocked T piece for that side.
Any ideas?
Thanks,
As MoggyT says, sounds like its blocked, Pull the pipe from the jet off the "T" peice, and get a airline, and blow air down the pipe (at the jet end) don't be pempted to blow up to the jet as if there is something there it will block it more.
also while the pipe is off the "T" peice try the washers and you should get water squirting out of the open fittingand also out of the passinger side
Radiotwo
