Octavia VRS LE Owners....Check Your Seats!
I have just noticed that on the drivers side seat there is a small chaffe mark on the leather, caused by the female part of the setbelt.
For some strange reason the passenger side seatbelt is taller, so dosnt suffer this problem.
Might be something to watch out for, as I can see this eventually chaffing through!
Only chaffes because you're pulling 3g around every roundabout.....
Please... its a Skoda James, not an F1 Car!
The seatbelt mounts are the same length on both seats, the reason I believe for the apparent difference is down to seat height. The anchorage point for the seatbelt is on the lower part of the seat base that does not move up/down, so if the drivers seat is set to a higher position it will give the impression that the seatbelt is shorter than the passenger side.
