Can anyone help? Front axle weight Octy 2 vRS?
As above
Can anyone help me please?
Need to order some bits for a customer , and he could not find the info
I have tried to Google search and searched on here
If you can help an old lady in need ;)
Sarah
Petrol or Diesel?
Carl
Oooh sorry
Petrol :blush: I thought I had put that
Sarah
Hmm can only seem to locate the Kerb Weight which is 1400kg Does that help?
I'll keep looking
Carl:thumbup:
axle weights are on the vin plate, for mot purposes...;)
you having the same issue i did. when i ordered the AP coilover sit gave you the two weight options with two strut diameter options.
i ordered the larger of the two and it is working sweet for me. front axle weight 1061-1160kg 55mm strut diameter.
folowing quotes stolen from venommotorsport
Skoda Octavia Octavia (1Z) Front strut diameter 55mm 2.0TFSi/1.9TDi/2.0SDi/TD Year: 9/03-
Product Notes
Height adjustable coilovers front and rear. Not for 4WD vehicles (Quattro, 4x4, 4Motion…). Only for vehicles with a clamp diamter of 55mm on the front axle.
Front Lowering: 30-90mm
Rear Lowering: 25-75mm
Front Axle Weight: 1061-1160kg
Rear Axle Weight: 1100kg
Octavia (1Z) Front strut diameter 55mm 1.6/2.0FSi Year: 9/03- Product Notes
Front Axle Weight: 1060kg
HTH
Sy:thumbup:
Ok my VIn plate has the following on
1950kg
3350kg
1 - 1100kg
2 - 1100kg
650kg
So im assuming its 1100kg
Carl:thumbup:
Do you mean the maximum load the front wheels on the car can carry? That should be in the tech section of the manual under axle loadings.
If you mean the weight of the front axle for shipping you'll have to find how much of the front suspension is involved (Not that I have a list of weights myself though). There is no part you could really call the front or the rear axle in an Octavia 2 as they have fully independent suspension, so the closest you get to axles are the shafts transferring drive from the gearbox to each of the front wheels.
Oooh guys
I knew I could count on you lot
Your all great
Yes the issue is with the front wieght for coilovers
I googled for hours :( and all I could get was kerb weight too
So nice one
Thank you all so much
Sarah
1950kg (Max Allowable Mass)
3350kg (Gross Train Weight)
1 - 1100kg (Front Axle)
2 - 1100kg (Rear Axle)
650kg (Trailer)
Carl:thumbup:
Although I would have thought that the GTW = MAM + Trailer?
HTH
Just for the record, here is the data from the Octy II Facelift Manual....
Can't seem to find the equivalent page in the original Octy II manual, but you have it above anyway.
I looked all over on google and downloaded all sorts of bits of info
That is why I decided to ask the clever guys on here
You did not dissapoint me :grouphug:
Sarah
HTH
It is, it's just that the Octi can pull 650kgs no trailer brakes and 1200-1450 kgs with brakes.
The axle load is also an issue when braking hard, the car tends to sit on its nose during that time.
