Fault Codes this morning! Help!
Got a slight stutter in third last night, at low revs. Changed down to 2nd and it seemed to clear. Then this morning, car started up fine but then started bunny-hopping. Engine check light flashing. Sounded rough, like all cylinders weren't firing and quite a lot of vibration through the car when on throttle! Had to drive on a bit, then I was able to check with VAG-COM. Got the following:
Saturday,11,July,2009,08:59:43:65146
VCDS Version: Release 805.4
Wardy
Address 01: Engine
Control Module Part Number: 1Z0 907 115 A
Component and/or Version: 2.0l R4/4V TFSI 0040
Software Coding: 0203000318070160
Work Shop Code: WSC 00191
4 Faults Found:
000665 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 35007 km
Time Indication: 0
Date: 2000.00.00
Time: 14:07:04
Freeze Frame:
RPM: 3964 /min
Load: 81.1 %
Speed: 135.0 km/h
Temperature: 85.0°C
Temperature: 35.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.097 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 35548 km
Time Indication: 0
Date: 2000.00.00
Time: 08:41:12
Freeze Frame:
RPM: 2021 /min
Load: 19.6 %
Speed: 42.0 km/h
Temperature: 48.0°C
Temperature: 17.0°C
Voltage: 14.605 V
000769 - Cylinder 1: Misfire Detected
P0301 - 001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 35548 km
Time Indication: 0
Date: 2000.00.00
Time: 08:41:13
Freeze Frame:
RPM: 2100 /min
Load: 24.7 %
Speed: 42.0 km/h
Temperature: 48.0°C
Temperature: 17.0°C
Voltage: 14.605 V
008597 - Oxygen (Lambda) Sensor B1 S1: Signal too Low (Lean)
P2195 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 35553 km
Time Indication: 0
Date: 2000.00.00
Time: 08:45:16
Freeze Frame:
RPM: 2116 /min
Load: 26.7 %
Speed: 71.0 km/h
Temperature: 84.0°C
Temperature: 18.0°C
Voltage: 14.478 V
Readiness: 0000 0000
Fuel issue, or something more serious? Currently running a tank of Tesco-99, from the same station I always used. Between a half and 3/4 remaining.
Thoughts and suggestions please. Otherwise it doesn't look good for a trip down to the National tomorrow :(
Thanks,
Steve
Edited by Wardy
Bit of extra info
Sounds like it could be coil packs mate casuing the other faults.
Try changing the coil pack on Cylinder 1.
Dunno if you have got any but Skoda Assist/RAC Usually have them although when mine went they didnt. :rolleyes:
I had a similar list of faults when my coilpack went
HTH
Carl:thumbup:
Thanks for the info mate. Got a VW garage just down the road, so could pop down there for one. I do have breakdown cover, but now sat at home as I wasn't going far, so seems a bit pointless. If it's easier I'll just go down to VW. You got a Part Number handy? :)
Cheers,
Steve
06F 905 115 F
Might wanna get a couple mate. I had it explained to me that when one goes they all seem to go over time till you end up replacing all four.
They are about £31 each iirc.
If thats not the problem take the print out with you to the VW garage and ask if the Technician can have a look at the faults. They should be able to tell you more accurately if that is the problem or something else.
Carl:thumbup:
Hi Wardy
Try swapping them round
If it is a coilpack , then the fault will swap with it
If 1 has failed , may be worth getting all 4 done , to save the issue again
But as I said swapping will just double check it for you
Sarah
Oooh Mater beat me to it :thumbup:
Sarah
Gotta be quicker than that Sarah :P
:( sorry , must try harder :lol:
Sarah
Thanks people! :D
Coilpacks it is then. Seems to be intermittant, as I cleared the faults and did a 10min test round some country lanes nearby. Couldn't seem to reproduce the stuttering/hesitancy in 3rd, but then minutes from home on a light throttle uphill in 4th, bunny-hopping/vibration returned, along with a flashing engine check light :rolleyes:
Need to look up how to change them now! ;) But you reckon I should just bite the bullet and buy four?
Steve
Just rescan, and faults have 768 (random cylinder misfire) and 769 (cylinder 1 misfire) have returned. Does that suggest that two of the coilpacks are maybe faulty at the same time?
Steve
Where abouts are you steve i can give you a hand if you wish as im in Cheshire.
If not its a piece of pi55 to do. Remove engine cover, you will see the 4 coilpacks on top of engine. Unscrew the 2 Torx screws that hold in the Ignition electrics. Unclip each coil pack and pull off connector gently towards back of engine bay. Lift out coil pack (they go L-R 1-4) insert new one and reconnect everything back up. It literally takes about 2 mins.
As for the Random cylinder fault im not sure. I do remember having roughly the same fault codes as you when mine went but unfortunately i never kept the readout once id sorted it. It could just be from the one or it could be that any number are going upto all 4 of them
As for buying all 4 its up to you. Mine went at about 36k. Im on 42k now and no others have gone. But i have spare now just incase. I would defo say get at least 2 and keep the old ones in till they do go.
If you have any probs PM me and im sure i can pop round to sort it for you.
Carl:thumbup:
Thanks, just sent you a PM too :thumbup:
Steve
Just rang the local VW dealer and they've got two in stock, so I'll get them both. Part number has changed apparently, but I'll update with that when I get them.
£27.91+VAT, so £31.10 each.
Cheers,
Steve
If its still under warranty then call Skoda Assist. They keep them on board and it won't cost you a penny :)
Thats what I did when my 2 went.
Just outside now unfortunately Tom, by about 6 weeks. Typical :rolleyes:
Steve
If it is the 07k ones , we have 3 in stock too ;)
Sarah
Yep 07K :thumbup:
Good to know, but the VW place is nearer :)
Think I'll just replace the cylinder 1 pack straight away, then go for another road test. Bit confused random/multiple cylinder error code though, as surely engine management would know which cylinder was not behaving correctly :confused:
Steve
Cheers,
Steve
Bloody hell i only got mine in Feb and the part has changed again :eek:
Oh well hopefully it will be all sorted for you.
Damn my memory is good :P £31.10 i was only 10p out :D
Carl:thumbup:
Yes , your typing is fast too..... :P
Sarah
Sarah
Along with a few other things ;):D
Carl:thumbup:
:rofl:
Carl:thumbup:
:blush: dont want to know about them :eek:
Well if you need them , pop along , then you can get an R8 cap for Mater while your at it :rotz: I will be leaving soon , sorry
Sarah
Off to VeeDub now, will then fit them, test and see what happens.
Wish me luck :)
Sarah
Trust you to think the wrong thing :eek:
I was talking about my Car :P Honest :rolleyes:
Carl:thumbup:
Wish me luck :)
Good luck
Sarah
