Help! How do you remove door lock
Hi,
I'm trying to free the door lock to have a look at fixing a dodgy microswitch. I've removed everything as per the ancillaries guide (http://briskoda.net/technical-guides/removing-ancillaries-carrier/133384/), and I've unscrewed the two bolts holding the lock in place. The only thing stopping me getting the lock out of the car is the cable running from the exterior door handle to the lock mechanism. Can anyone help me disconnect the cable? Would appreciate quick replies because my door is in bits at the mo and I'm freakin out a little bit. :eek:
Thanks,
Paul
Edited by ninjajebus
All done, not fixed yet my problem with the microswitch, but the door is back together again, I had to take apart the other door to see how it all worked. I was well out of my comfort zone, tho I'd be much happier doing it again next time.
