[Octavia vRS mk1] Pictorial: Installing new component speakers with crossover in door
I treated my Octavia vRS '04 with some new component speakers for the front doors from Rainbow Audio. I decided to take some photographic evidence on the fitting process. I only depict installation on the passenger side front door. The driver's door is identical, except for the removal and installation of the door card, which is slightly different.
Since pictures tell more than words, I will not describe the work in detail.
Removing door card
Based on Rob's excellent guide for uninstalling the rear door card.
Step 1: Unscrew torx screws
full
full
Step 2: Pop out electric window switch and unscrew screw
full
full
full
Step 3: Remove trim from door handle
full
full
full
full
full
full
full
Step 4: Remove two screws from door handle
full
Step 5: Pop out tweeter casing perpendicular to door
full
full
Step 6: Disconnect wire for door handle and door light
full
full
full
Step 7: Lift door card straight up and revel
Edited by kirk
Speaker installation and tweaking
Loosely based on Scodillac's instructions on how to tweak woofer mounting.
Step 1: Remove original speaker
full
full
full
full
Step 2: Remove speaker mount
full
full
full
Step 3: Remove speaker sealing membrane
full
full
full
Note: in the picture above, this metal edge will hit speakers that are too deep. It can easily be bent or cut away, if one wants to install deeper speakers.
Step 4: Create waterproof seal which allows speaker to breathe into door (out of duct tape)
full
full
full
full
full
NOTE: Eave goes into door, so that water should not poor into speaker bay, unless car is upside down.
full
Step 5: Check speaker mount edge for air leaks
full
full
full
Edited by kirk
Step 6: Insulate speaker mount edge with thick two-sided tape
full
full
full
Step 7: Install speaker mount
full
Step 8: Make speaker wires to connect new tweeter with VAG speaker connector
full
NOTE: You can buy adapters to connect to VAG speaker connectors from for example ebay. Google for 'PC2-805'
Step 9: Connect speaker wires between woofer-crossover, tweeter-crossover and input-crossover
full
full
Step 10: Modify crossover to fit door installation
full
full
full
Step 11: (Re-)fasten styrofoam insulation piece to door with thick two-sided tape
full
full
full
full
Step 12: Fasten crossover onto styrofoam insulation piece with thick two-sided tape
full
full
full
Edited by kirk
Step 13: Connect speaker components with crossover and install woofer (some cotton added, polyester filling would be better)
full
full
full
full
Step 14: Remove original tweeter from tweeter mount
full
full
Step 15: Install new tweeter to tweeter mount (mine needed to be tweaked with a Dremel to fit snug)
full
full
Step 16: Fasten door card (reverse of removal)
full
NOTE: If door handle doesn't work properly, make sure door handle wire plastic plug is in groove.
:D
  • 1 year later...
Very useful guide for me, thanks
