APR Manifold
I see that awesome are now doing ABD manifolds, wooop!!:thumbup:
Awesome > ABD Racing Performance Intake Manifold 1.8T
on the little write up it sais to expect gains of 12-20+bhp
would that be on a standard turbo, or a larger item?
also what else would be needed to make it worthwhile fitting to my car? 4bar injectors??
mark
Edited by mark_sargeant19
my crappy spelling (like in the title)
sarah has said it is for the standard turbo..
but i think its only good for big turbo thats why des etc are running it....
you will not get up to 20bhp by adding it on a standard turbo simple as that......i have emailed them again as i was told by them its only good for the bigger turbo and no real point running it with the standard turbo...
other mods would be everything to be honest including bt upgrade....
as running a ko3s it will not go above 240 to 250 max with everymod available.....
nah i didnt think there was a chance of getting anywhere near 20bhp,
im not planning a bigger turbo, so i guess it might be a bit of a waste for me,
although i do like the idea of getting the manifold as its nice and shiny and saves me having to polish my current one :rofl:
It does look spanky though!
bling bling.
Yes, Awesome is our newest addition to our worldwide network of ABD Racingwerks Authorized dealers!
Please feel free to contact them with any of your ABD needs.
the ABD intake mani is good for approx 12-20hp and yes, those numbers are based depending on what else is modified on the car. We have seen the 10-12hp number on stock cars. It is still a mod worth doing even if you have no plans for BT set-up.
p.s. you may do a larger injector set up with the ABD manifold if your ECU software supports them.
cool that clarifys that then
have you got some rr graphs of claimed figures with a list of mods that car has ????? :confused:
so we can see the gains for ourselfs on a stock car...
also have you go the flow rates of the intake manni??
if it is that good i will be ordering one :thumbup:
Bengie will you be running WMI?
Same as westallc, I too will order one if gains can be proven ?
I suspect an ABD mani would give no gains as the std mani is good for over 300 bhp, and it might actually loose a bit of torque due to the shorter runner lengths.
Hope to be proven wrong.
he's mentioned WI in the past, but I don't see it happening with the GT28. what happens with the GT30? who knows?
the runners aren't that much shorter, yes the plenum is bigger so making them shorter but they appear shorter than they actually are due to them being wider :)
WMD's might happen in the future, who knows but as said it definitly won't be happening on the 28 :)
I'm feeling in a helpful mood today. :rolleyes:
VWvortex Forums: ***1.8T Intake Manifold Test Results***
Al lot of stuff about flow rates on that but in the whole 11 pages I didn't see anyone who'd dyno'd a standard car then added the new manifold. Did I miss it?
thanks des makes a change you grumpy mod git lol ;):rofl:
so the flow on the abd unit isnt that good compared to others!!!!
des why did you choose abd and not one of the better flowing units???
must say its a lot cheaper than the other :D
Rob i'm with you,as it doesn't.
I know the SCN boys have had good results with the SEM manifold but that's on the wrong side.
Who's going to be the 1st?
jay the first to do what???
its not that simple really clive as that test covers and mixes up small port and big port manifolds, the ABD is a small port manifold and is the 2nd best small port in the test, only 12% below the best but is over 32% better than a standard small port manifold. :)
the first to what?
as already said Des and I both have this manifold but neither are running it on a standard turbo.
the first to what?
To try it on standard K03s.
When are you hoping to have yours running or is it running now?
and i only just had a new manifold fitted but it was ported and polished so should be a bit better lol
may have to get an abd one soon......
.( may have to pop to unit 18 with some spanners):D;) now wheres bens engine lol
and you was selling the car?:D
Didn't yoou say you weren't spending any more on it?:rofl:
i know thats the way the cookie crumble i guess and there's me about to spend some more on a new exhaust manni and turbo lol
lifes a bitch and then you buy a car
I've heard that some people just buy a car and use it as transport without modifying it.
Wierdos.
PM which your after as i saw your post over on SCN.;)
