Rear caliper refurb?
I have just order a rear calliper from brakes international after reading this post as my o/s/r is sticking badly. Do you need vag com to turn abs off to bleed the brakes as stated earlier in the post?
Did you manage to get a green one? I rang them this morning and they said the green one isn't available anymore, and they can only supply standard ones.
Oh, nd you don't need vagcom as long as you clamp the brake pipe to stop air getting to the abs module.
No same as you so I got a standard one for £73 + vat and then a £5 halfords ford Modena green spray and it looks spot on.
