Help !!!!!! Lost 5th Cog and 3rd on the wayout!
Well i lost 5th cog this morning on the motorway 3rd also seems to on the way out too!(03 plate octy VRS) now before anyone says anything :rolleyes: the car is ex police and has done 97k (96k when i bought her)
question really is.... what gear box does the mk1 gearbox have in it? same as golf gti?
code???? ENJ:confused: EVS:confused:
as its looking like i'll have to put another one in:(
Guest westallc
o2j gearbox mate golfs will have the same aswell
have you checked the linkage as those have been known to go wrong :confused:
hope you get it sorted :thumbup:
can get all gears except 5th and 3rd is getting dodgy so the mk4 golf gti is exactly the same box?
Guest westallc
£1300 you are having a laught arnt you thats very very expensive for that.....
i knew someone selling an o2j fully rebuilt with uprated sncro's bell housing sand blasted so as good as new with a lsd diff with apr bolts and a lightweight flywheel and spec clutch for 1200 fitted so i would say you payed well and truly over the top buddy
Have the linkage at the base of the gear stick checked over. My Fabia gear box 'Failed' losing 3rd and 5th. The AA sorted it out with a replaced grub screw...
yeah, check the engine mountings (particularly the nearside one under the airbox) - mine broke, allowing the gearbox and engine to drop on that side with the result that I systematically lost 2nd then 4th gear...
especially if it's ex police:rofl:
It's ok folks it's all sorted now found the problem now have all gears again!!!! found the breather pipe on(or off) the airbox wedged between the bit of the metal and the edge of the block/gearbox pushed it back on so all is well
and all mounts are ok as i checked them when i bought it
Guest westallc
well thats alot cheaper than a gearbox lol
well done mate always worth alook before fearing the worst
all the best
clive
