Temperature sensor beep exp tank replaced
Thanks to help provided on here, I did the deed thismorning
Bought the new expansion tank about £11.87
Removed and replaced in about twenty minutes this morning
clamped bottom pipe and drained remainder of tank
Removed two nuts and then two bolts, lifted out and disconnected two hoses
threw old tank in bin
Reversed procedure Job DONE twenty minutes max
I could have done this at the roadside, (infact I did as I was parked up five doors away and could not get access to my drive)
Many thanks to xxx I can not find his name in recent posts, though I did not need to do a lot of what was shown (loom and frame removal)
My Quick Fix Blog Archive Skoda Fabia VRS, temperature beep, expansion tank replacement
National
