Battery casing removal??
right chaps( + chapesses)
Fab 1.4 8v
weve established that my PAS resevoir is nicely tucked out of reach, under my battery. :thumbup: top work skoda!!
So now what i need help with is........ how to get the battery/and casing out with out disconnecting the battery.
not sure wether the battery housing and air filter housing are on the same bracket or not?
Maybe Rob or Ross may know??
cheers
Lee
can't remove it and leave battery connected i'm afraid
surely you can jsut use a jumper cable and 'short it' so ure not actually disconnecting the battery.
what problems would disconnecting the battery cause?
Didn't cause any on my Octy.
Radio came up with code - no problem.
Leccy windows needed retaught, doddle.
Part from that - great.
