Cupra R Brembos
Wanted to change wheels but i went in to one wheel emporium and they said they have tried so many wheels on them but none will clear the calipers!
I was looking to get 8" x 18" wheels
Any help appriecated!
most will clear with a small spacer of about 4 to 5 mm....
18 should be fine shouldnt even need spacers buddy :thumbup:
mmm so 18x8 et 35 should clear the Brembos? If thats the case then I might go for some.
the 6 pot compbrake ones are a bit too steep at the mo. in green of course
just depends on the offset of the wheel itself.
There are some 17s that will work without a spacer apparently avus s3 alloys will however most (like the spiders do require spacers), i have 10mm for the brembos i am going to fit.
Billy, the compbrakes are the same price (if not cheaper) than the brembos are, and are a 6pot kit with lightweight alloys bells and brackets that should be a better setup than the 4pot brembo kit.
unless you can get a secondhand brembo kit for a good price, i was lucky!
Aren't the 225 Cupra R discs a non-common size (323x28mm), so they're expensive and options are limited?
Did the 210 Cupra R have the Brembo 4pots? Because that one has the same discs as the vRS (312x25mm). Or is that what we're talking about?!
Find out what size wheels the Cupra R has, then match to that.
yes the cupra r discs are 323mm,
the 210 (i thought) had 323mm discs as well as all the cupra r's to my knowledge had 4pot brembos.
Dont think the stock cupra r caliper is the same as the brembo gt caliper kit that i have though the discs are the same.
Now if we are talking expensive discs the r32 ones are EXPENSIVE!
Cupra r ones are not too bad considering. The cupra r wheels are 18" though not sure of offset. They are my fav wheel actually and when i can find some for a good price i will buy them!!!
I have a set of carriers to fit the brembo calipers to 312mm discs that came with my kit, though as i can fit 323discs am not sure why you would use the smaller discs unless you didnt want to pay the extra for the 323s!
Well i have current have mile migla 17" wheels that look almost identical to the Cupra r wheels but i want to change them
any pics?
well i guess you will prob need a 6-10mm spacer.
